Difference between "MC33FS8530A0ES" and "MC33FS8530A1ES"
1,535件の閲覧回数
Bhavay
In my previous comment, unfortunately I didn't shared enough information. This is the power management IC with internal SPI port, Buck and Boost converters. I want to use this part in my recent project, facing unavailability problems. In the same product datasheet, same part with "MC33FS8530A1ES" part name is available with target application 'CAMERA'. Can anyone please clarify the difference between both parts.
Attaching the link below for reference : https://www.mouser.in/datasheet/2/302/PB_FS84_FS85C-1947521.pdf
タグ(1)
5 返答(返信)
1,522件の閲覧回数
JozefKozon
Dear Bhavay,
MC33FS8530A0ES is a non programmed version. The OTP (One Time Programmable) registers are not set.
While the MC33FS8530A1ES has the OTP registers set with specific values for all the regulators output voltage, current, functions etc. For the OTP settings please refer to the FS84-FS85 full datasheet, section 4.1. Please download the full datasheet from the FS8500 product page under the secure files.
With Best Regards,
Jozef
1,491件の閲覧回数
Bhavay
Hello Jozef,
Thanks for your reply!
while accessing the secure file in the portal page, It shows "There's no information to display". Can you mail the datasheet pdf file on bsen@aartechsolonics.com. or share it on my Whatsapp "+91-9926316541"
Bhavay sen
1,481件の閲覧回数
JozefKozon
Hello Bhavay,
please click on the link "request access rights". They should grant you access to the documents.
I have checked our NDA database and your company has a valid NDA (Non Disclosure Agreement) with NXP. Unfortunately I cannot share the confidential documents via community. Please create a new ticket here. In the Subject please write "continuation of a case #00555970". Then I can share the datasheet via ticket.
With Best Regards,
Jozef
1,468件の閲覧回数
Bhavay
Done. I created a case with all required details.
Thank you.
1,446件の閲覧回数
JozefKozon
Hi Bhavay,
thank you for letting me know. My colleague has taking care of the new case. She will send you the required documents.
With Best Regards,
Jozef
