cp: target '/usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc//opt/freescale/rootfs/ppc//usr/local/lib/gcc/powerpc-none-linux-gnuspe/4.3.2' is not a directory
1,146 次查看
xuchen
With the Ubuntu14.04 and 10.04, I use the ltib to build p2020rdb, but it appeared error like this:
Processing: gcc-4.3-74
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/rootfs//var/lib/rpm --target ppc --define '_unpackaged_files_terminate_build 0' --define '_target_cpu ppc' --define '__strip strip' --define '_topdir /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/rpm' --define '_prefix /usr' --define '_tmppath /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp' --define '_rpmdir /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bi --short-circuit  /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc-4.3-74.spec
Building target platforms: ppc
Building for target ppc
Executing(%install): /bin/sh -e /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/rpm-tmp.73320
+ umask 022
+ cd /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/rpm/BUILD
+ cd gcc-4.3.2
+ rm -rf /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc
+ [ powerpc-none-linux-gnuspe- = arm_v6_vfp_le- -o -n  ]
+ perl -n -e s,-$,,;print
+ echo powerpc-none-linux-gnuspe-
+ OPT_CFGHOST=powerpc-none-linux-gnuspe
+ [  = 64 ]
+ SLIBS=lib
+ EXTRA_CONFIG=
+ EXTRA_CFLAGS=
+ BUILD_TARGET=powerpc-none-linux-gnuspe
+ powerpc-none-linux-gnuspe-gcc -mcpu=8548 -mspe=yes -mabi=spe -mhard-float -mfloat-gprs=double -print-file-name=crti.o
+ dirname /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crti.o
+ CRT_FILES_DIR=/opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib
+ sed -e s,-$,,
+ X_DIR=powerpc-none-linux-gnuspe
+ mkdir -p /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc//opt/freescale/rootfs/ppc//usr/local/lib/{,gcc/powerpc-none-linux-gnuspe/4.3.2}
+ cp /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/Mcrt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/Scrt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crti.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crtn.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/gcrt1.o /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc//opt/freescale/rootfs/ppc//usr/local/lib
+ cp /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/Mcrt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/Scrt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crt1.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crti.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/crtn.o /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linux-gnuspe/powerpc-none-linux-gnuspe/libc/usr/lib/gcrt1.o /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/gcc//opt/freescale/rootfs/ppc//usr/local/lib/gcc/powerpc-none-linux-gnuspe/4.3.2
error: Bad exit status from /usr/local/ltib/ltib-p1020rdb_p2020rdb-20101029/tmp/rpm-tmp.73320 (%install)
RPM build errors:
Build time for gcc-4.3-74: 0 seconds
Failed building gcc-4.3-74
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Tue Jun 21 12:39:26 2016
Ended:   Tue Jun 21 12:49:33 2016
Elapsed: 607 seconds
These packages failed to build:
gcc-4.3-74
Build Failed
Exiting on error or interrupt
when i check the path, i found :
as
Who had the same problem? and how to solve this problem?
标记 (1)
7 回复数
885 次查看
Pavel
You are right. Any changes in LTIB configuration produce gcc problem.
This BSP is too old. Use NXP Linux SDK for the P2020rdb board:
http://www.nxp.com/products/software-and-tools/run-time-software/linux-sdk/linux-sdk-for-qoriq-proce...
Use SDK 1.9 for the P2020RDB board.
Pavel Chubakov
885 次查看
Pavel
I have created new virtual machine, install Ubuntu 10.04 on this machine.
The following command sequence was used for LTIB building:
  1. 1. sudo apt-get install autoconf automake libtool gettext x-dev xorg-dev patch g++ rpm zlib1g-dev m4 bison libncurses5-dev libglib2.0-dev gettext build-essential tcl intltool libxml2-dev liborbit2-dev libx11-dev ccache flex uuid-dev liblzo2-dev
  2. 2. mount .iso file and install LTIB.
  3. 3. issue command "./ltib" in the ltib-p1020rdb_p2020rdb-20101029 folder.
The following message was aapeared:
To configure this, as root using the command "/usr/sbin/visudo",
and add the following line in the User privilege section:
pavel ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
  1. 4. Add recommended line and issue "./ltib" command again.
Attached file screenshot.
Pavel Chubakov
885 次查看
xuchen
Hello dear Pavel,  my question is:
I can install ltib success, when first run ./ltib, the default platform type is P1020 RDB board, I can build success with the platform of P1020 RDB board, but I want to choose the platform type of P2020RDB, the problem  appeared.
885 次查看
Pavel
We recommend using Ubuntu 10.04 for LTIB building.
Ubuntu 12.04 also can be used for LTIB building.
Use the following command before LTIb installing under Ubuntu 10.04:
Do you use Ubuntu 10.04 for LTIB building?
Pavel Chubakov
885 次查看
xuchen
I tried to build ltib in ubuntu10.04, I choose the board P2020RDB,but appeared the same question:
885 次查看
xuchen
When i install x-dev, an error occured:
the others installed ok. Does it mater
danfengch@163.com
885 次查看
xuchen
I use Ubuntu 14.04 for LTIB building.
danfengch@163.com
