Hello david howard,
If you still encounter transfer error after create necessary PAACE entries, please dump the PAMU configuration as follows:
* dump the DMA n Logical I/O Device Number Register (DMAnLIODNR), to get the LIODN number, for example liodn=0xc4
* dump the Primary PAACT Base Address Register for 64-bit physical address of PAACT, for example base=0x28188000
* dump the PACCTs for DMA n at physical address = 0x28188000+0xc4*0x40 = 0x2818b100, make sure both source and destination address are configured correctly
You could compare your configuration with the default configuration on Linux.
Lunmin
