Regarding libpowerpc content query
1,581件の閲覧回数
vasanthsri
Hi Experts,
We are currently working on P4040 processor and while investigating one problem (related to mul instructions) came across this custom library (libpowerpc) and have below query.
Could someone help me on explaining the content (what are the custom changes) and also the source tar ball (if possible).
Thanks.
1,303件の閲覧回数
yipingwang
Hello Vasanth Sri,
I sent the source tar ball to you, it's about 9.5 M, please check whether you could receive it.
Yiping
8 返答(返信)
1,303件の閲覧回数
vasanthsri
I recently checked the freescale "Freescale Linux SDK v1.6" document and under section 9.4 can see one libpowerpc library is explained.
http://cache.freescale.com/files/soft_dev_tools/doc/support_info/QorIQ-SDK-1.6-IC-RevB.pdf
Could someone help on retrieving the library (lib_e500mc.so) or source from below mentioned path ?
<sb_path>/build_p4080ds_release/work/ppce500mc-linux/libpowerpc-1.1.0-r0/libpowerpc-1.1.0
Thanks in Advance.
1,303件の閲覧回数
vasanthsri
Any luck ? Could someone kindly let me know about the possibility of getting this (above requested) source file from latest SDK ??
1,303件の閲覧回数
yipingwang
Hello Vasanth Sri,
In SDK 1.6, this package should be named as "libppc", please run the command "bitbake libppc -c patch -f", you will get the source code in build_p4080ds_release/tmp/work/ppce500mc-fsl-linux/libppc/git-r0/git/.
Yiping
1,303件の閲覧回数
vasanthsri
Thanks for the prompt Yiping.
Is it possible to share this library content alone as an attachment for ppce500mc platform .? Thx.
1,303件の閲覧回数
vasanthsri
Could someone help on providing the direct "libppc" source content as an attachment ?
Thanks .
1,303件の閲覧回数
vasanthsri
An help.? Due to the limited bandwidth I am not able to do the extraction and build. Could someone help to retrieve the copy of this library content alone if possible ?
Thanks.
1,304件の閲覧回数
yipingwang
Hello Vasanth Sri,
Yiping
1,303件の閲覧回数
vasanthsri
Thank you. (y)
