How to get P2020 DMA over PCIe to transmit more than one data byte per packet?
620 次查看
toddreed
We have adjusted the BWC (Bandwidth/pause control bits of DMA mode register), but haven't seen any change.  We always get one data byte.  Thank you.
Todd
489 次查看
LPP
Please check the value of DMAx_MRn[DAHE,SAHE] (RM Section 13.3.1).
Probably, you are trying to DMA data to FPGA register on the PCIe side of DMA. DMA doesn't burst if DAHE,SAHE != 0.
The source/destination transaction size calculations provided in RM Section 13.4.1.1 is only applicable to the case of DAHE,SAHE = 0.
Pavel
490 次查看
LPP
Pavel
