Hardware Signal Ambiguity - cfg_rcw_src(0:4), most significant bit?
bobkorkuc
I am a hardware engineer and am confused by how to associate the cfg_rcw_scr(0:4) to the actual Hardware Signals. The confusion results in not being able to determine the most significant bit for the cfg_rcw_scr bits.
For the hard coded table shown above, Table 4-32, for a 1_0010 equating to cfg_rcw_src(0:4), what is the most significant bit, cfg_rcw_src[0] or cfg_rcw_src[4]?
For the LGPLx hardware signals shown below, it is ambiguous which is the msb when you write cfg_rcw_src(0:4) = 1_0010. Hardware convention suggests that the left most digit is the msb and it is cfg_rcw_src(0).
Cfg_rcw_src[0] = LGPL0
Cfg_rcw_src[1] = LGPL1
Cfg_rcw_src[2] = LGPL2
Cfg_rcw_src[3] = LGPL3
Cfg_rcw_src[4] = LGPL5
Can someone clarify the ambiguity?
Bob
Labels (2)
LPP
In the expression "cfg_rcw_src(0:4) = 1_0010", the bit sequence is the same on the left and right sides.
I.e. cfg_rcw_src[0] = 1 and cfg_rcw_src[4] = 0.
Pavel
