I would like to flash a u-boot image on the p2020rdb board. Assuming the original u-boot image is corrupted and the board cannot boot up, how I can flash the u-boot onto it? Also, is there a working u-boot image so that I can verify the method?
I do have an old CodeWarrior JTAG debugger but not sure where I can get the working software associated with it.
Thank you for your help.
解決済! 解決策の投稿を見る。
NXP offers SDK 1.9 for the P2020RDB board. This SDK supports booting from SD card.
Write u-boot to SD card and use this card for booting if u-boot is damaged.
Pavel Chubakov
Hi Pavel,
Can you advise how to configure p2020rdb to use the u-boot code from different storage such as NOR flash, NAND flash, and SD card? Thank you!
I found a legacy user manual that explains this. So the problem is solved. Thank you.
Pavel Chubakov
