CPC Partition when I using CPC as SRAM P4080
996件の閲覧回数
hymalaibello
Hi!
Can I use the registers for  Partition allocation of CPC (CPC1_CPCPAR1....) when I am using CPC as SRAM?  Is for assign  a private space to each core.
thanks!
Hymalai Bello
3 返答(返信)
702件の閲覧回数
yipingwang
Hello Hymalai,
This register is used in the case of PAMU is enabled, users could program CPC registers CPCPIRn, CPCPARn and CPCPWRn to restrict allocation for several partitions when PAMU enabled, and this level of configuration is performed by hypervisor.
In the Soc each core has its own TLB, I think you could configure TLB entries to implement your purpose to allocate a specific partition of CPC as SRAM for each core.
Yiping
702件の閲覧回数
lunminliang
Do you plan to use part of the CPC as SRAM and the rest as L3 cache? I am afraid it's shared among cores.
702件の閲覧回数
peterzheng
Hi Lunmin,
I also have similar question? If I want to divide the CPC into 8 equal parts, and let each core use 1 part of CPC, how to achieve that? Is it through setting the register?
Peter Zheng
