About u-boot device tree
1,414件の閲覧回数
saadahmad
I am using P2041RDB. I need to add a config DTB at the end of u-boot image by using CONFIG_OF_SEPARATE.
According to common/board_f.c function setup_fdt()
#elif defined CONFIG_OF_SEPARATE
  /* FDT is at end of image */
  gd->fdt_blob = (ulong *)&_end;
But there is no _end in u-boot.lds of mpc85xx. I have changed _end to __bss_end but u-boot is not finding any DTB at the end of the image.
Thanks in advance for any help you are able to provide.
タグ(2)
3 返答(返信)
781件の閲覧回数
Pavel
We use SDK from NXP.
The following command sequence is used for u-boot building under SDK:
bitbake -c cleansstate u-boot
bitbake -c patch u-boot // source of the u-boot
bitbake u-boot
Pavel Chubakov
781件の閲覧回数
Pavel
NXP SDK 2.0 does not support this option of the u-boot. There is error message during u-boot building if CONFIG_OF_SEPARATE is defined.
Pavel Chubakov
781件の閲覧回数
saadahmad
I am not using SDK 2.0. I just want to know where to put the _end (end of u-boot image location) in u-boot.lds.
Saad
