I am using P2041RDB. I need to add a config DTB at the end of u-boot image by using CONFIG_OF_SEPARATE.
According to common/board_f.c function setup_fdt()
#elif defined CONFIG_OF_SEPARATE
/* FDT is at end of image */
gd->fdt_blob = (ulong *)&_end;
But there is no _end in u-boot.lds of mpc85xx. I have changed _end to __bss_end but u-boot is not finding any DTB at the end of the image.
Thanks in advance for any help you are able to provide.
We use SDK from NXP.
The following command sequence is used for u-boot building under SDK:
bitbake -c cleansstate u-boot
bitbake -c patch u-boot // source of the u-boot
bitbake u-boot
Pavel Chubakov
NXP SDK 2.0 does not support this option of the u-boot. There is error message during u-boot building if CONFIG_OF_SEPARATE is defined.
Pavel Chubakov
I am not using SDK 2.0. I just want to know where to put the _end (end of u-boot image location) in u-boot.lds.
Saad
