when i use gdb to trace my program, it started at Reset Handler, and when running to
ldr r0,=SystemInit, it will crash, and got into hard fault, how do i debug the program
Before answering your question, I was wondering if you can introduce the testing environment, for instance, board, code, IDE, etc.
TIC
i am using bare metal c without os, and i found that when entry
I'd like to know whether the issue happens when debugging with the MIMXRT685-EVK board.
TIC
