problem while adding both systemd and sysvinit on yocto
次の代わりに検索
816件の閲覧回数
Chethan
I am using LS1046ardb board for one of my project, in that I want add the recipes of systemd and sysvinit so that I tried modify the local.conf like below.
DISTRA_FEATURES_append = " systemd"
DISTRO_FEATURES_BACKFILL_CONSIDERED += "sysvinit"
VIRTUAL-RUNTIME_init_manager = "systemd"
VIRTUAL-RUNTIME_initscripts = "system-compat-units"
But in that I am able to configure the Systemd on root file system NOT rcS.d and all (related files of sysvinit).
commands used to build root file system is
1. flex-builder -i clean-rfs -r yocto
2. flex-builder -i mkrfs -r yocto:devel -a arm64
Please throw some light to move forward this problem
Thanks & Regards
Chethan GR
3 返答(返信)
798件の閲覧回数
yipingwang
I discussed this issue with the flex-builder developer.
If systemd is used, sysvinit rc0.d rc1.d rc2.d rc3.d rc4.d rc5.d, rc6.d & rcS.d folders in /etc folder should not be needed any more.
Integrating both systemd and sysvinit in rootfs simultaneously is not reasonable.
780件の閲覧回数
Chethan
If I added both Systemd and Sysvinit in root file system what problem will cause? Please let me know.
Thanks & Regards
Chethan GR
764件の閲覧回数
yipingwang
It is impossible for Yocto to integrate both systemd and sysvinit into the rootfs filesystem, there is conflicting problem to integrate both, because both systemd and sysvinit contain "init" script.
So you only could choose one init manager tool systemd or sysvinit.
