I'm starting evaluating i.mx93 board. I'd like to run WIN 10 IoT OS.
I'm wondering what is the best way to disable JTAG in production. The result to achieve is that no one can estabilish a jtag connection and read memory. Is there a way to do so?
Thanks.
Solved! Go to Solution.
Hi @marco95!
No, all made for Windows 10 are something confidential due to the licenses that Windows has.
If you need support to customize Windows 10 for your product should be under pro support.
Sorry for the mistake!
Best Regards!
Chavira
Hello, you mean "i.MX 93 Applications Processir Security Reference Manual"?
I attached an image of the description found. How can I get more about the description? Are there any resource example to get started?
Hi @marco95!
We have the next user guide for iMX Windows 10:
https://www.nxp.com/docs/en/user-guide/IMXWGU.pdf
Best Regards!
Chavira
Hi @marco95!
Best Regards!
Chavira
Hi @marco95!
Thank you for contacting NXP Support!
You can consult the iMX93 Secure Reference Manual in the chapter "Secure Debug" to consult the best way to protect the SOC.
Best Regards!
Chavira
