i.MX Forums i.MX RT1170: Max Size of Ring Buffer in UART
MN19000
I am trying to use UART Ring Buffer. But I can not find it in documentations.
What is the Max size of Ring Buffer I can use for UART communication?
kerryzhou
Hi @MN19000 ,
  Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
  The Ring buffer size is determined by your requirement, so, the max size is determined by your definition.
In the SDK, size_t ringBufferSize
typedef unsigned int size_t;
I think the unsigned init size is enough to you.
Wish it helps  you!
kerry
MN19000
Thank you kerry.
This solved my problem, please close this case.
kerryzhou
Hi @MN19000 ,
  Thanks so much, please help to mark the correct answer to close this case, thanks.
Any new issues, welcome to create the new question post.
Kerry
kerryzhou
Hi @MN19000 ,
Wish it helps  you!
kerry
