how to reduce rootfs size
Punnarao
I am trying to reduce rootfs size for s32v234evb board. Please suggest best way to do it.
Regrads,
Punnarao
Bio_TICFSL
Hello Punnarao,
If you are in yocto it has the reduce filesystem at minimum for yocto system, core-image-minimal maybe you want to eliminate yocto and restart with minimal system. You should try other OS like ubuntu i minimal way, but this is not supported by NXP.
