S32DS_PV2.1 integration S32R294 V4.4 Mcal
binqin
Dear Sir:
      When I integrated the mcal, it reported an error as shown as the figure.
      I'm sure it has been included in the header file and other .c documents.
      Can you help me?
      Do you have any related tutorals?  And the whole projects for S32R294?
namnguyenviet
Unfortunately, I couldn't be able to import your project to my S32DS. I suggest that you can refer to the platform integration for S32R294: https://nxp.flexnetoperations.com/control/frse/download?element=13149807 or contact to your local FAE to get a better support.
Nam
namnguyenviet
Are you sure that you've shared the correct project? I see that your project is based on S32K1:
Nam
binqin
        Can you help to check it ? This is the right project which I just created.
namnguyenviet
Unfortunately, that specific example is not available. I could check your attached project, but it would take some days.
Nam
binqin
Hello Nam,
This is not the path of header files problem. We had tried a lot of times.
Can you help to give us a project of S32R294 integration mcal  in S32DS?
namnguyenviet
Please carefully check your path to generated header files.
Nam
