S32 Flash Tool error #3 for S32R45
aiweixin
    I want to use S32 Flash Tool to download file to flash.
    When i click "Upload target and algorithm to hardware...", it failed(error #3).
    Why? And can someone tell me its working principle, configuration?
Tags (2)
petervlna
You can refer to the user guide:
But best is to rise a ticket so it can reach tools team if you need further assistance.
Peter
petervlna
It looks like your connection with device is not set properly.
Have a look at start guide which you can find in doc folder
Peter
aiweixin
Hi @petervlna,
    I have a question: When i select "COM", i cann't set serial port baud rate. It seems the GUI will use default value.
    Can you tell me about the default value?
Best regards!
