Query on 100 Base T1 connector for SJA1110 board
965件の閲覧回数
vsreekanth
Hi All,
I am looking for SJA1110 Switch purchase. MR-T1ETH8 model has 6x 100BASE-T1 Ethernet cables with JST-GH GHR-02V-S 2-pin connectors. Are there any supported JST-GH GHR-02V-S to RJ45 connectors available to connect this Switch with a PC?
https://www.nxp.com/document/guide/getting-started-with-the-mr-t1eth8-evaluation-board:GS-MR-T1ETH8
Thanks and Regards,
Sreekanth
889件の閲覧回数
lukaszadrapa
As I can see in the block diagram that the transceivers are connected directly by MII interface. MDIO from LPC microcontroller is used only for configuration of the transceivers. So, it's based on physical layer only, LPC does not affect the traffic. It may just add some delay to the transmission.
Lukas
6 返答(返信)
790件の閲覧回数
vsreekanth
Hello Lukas, are there any Automotive TSN supported NXP End points available to work with SJA1110 switch.
Thanks in advance. Good Day!
922件の閲覧回数
vsreekanth
Thanks Lukas for the information on converter. Does it supports PTP and AVTP traffic, I mean can we use the converter in case of 802.1AS, IEEE1722 standard specific traffic?
910件の閲覧回数
lukaszadrapa
I believe the media converted should not affect this traffic.
Lukas
901件の閲覧回数
vsreekanth
Hello Lukas, we are planning to purchase this switch and converter for Audio and PTP traffic testing. Could you please confirm, whether it will support without any issues.
Thanks in advance. Good day!
890件の閲覧回数
lukaszadrapa
Lukas
946件の閲覧回数
lukaszadrapa
Hi Sreekanth,
100BASE-T1 can't be connected directly to a PC, you need media converter. Something like this:
https://www.nxp.com/products/interfaces/ethernet-/automotive-ethernet-phy-transceivers/ethernet-medi...
Or you can find a lot of others on the web.
Lukas
