Query on 100 Base T1 connector for SJA1110 board
1,080 次查看
vsreekanth
Hi All,
I am looking for SJA1110 Switch purchase. MR-T1ETH8 model has 6x 100BASE-T1 Ethernet cables with JST-GH GHR-02V-S 2-pin connectors. Are there any supported JST-GH GHR-02V-S to RJ45 connectors available to connect this Switch with a PC?
https://www.nxp.com/document/guide/getting-started-with-the-mr-t1eth8-evaluation-board:GS-MR-T1ETH8
Thanks and Regards,
Sreekanth
1,004 次查看
lukaszadrapa
As I can see in the block diagram that the transceivers are connected directly by MII interface. MDIO from LPC microcontroller is used only for configuration of the transceivers. So, it's based on physical layer only, LPC does not affect the traffic. It may just add some delay to the transmission.
Lukas
6 回复数
905 次查看
vsreekanth
Hello Lukas, are there any Automotive TSN supported NXP End points available to work with SJA1110 switch.
Thanks in advance. Good Day!
1,037 次查看
vsreekanth
Thanks Lukas for the information on converter. Does it supports PTP and AVTP traffic, I mean can we use the converter in case of 802.1AS, IEEE1722 standard specific traffic?
1,025 次查看
lukaszadrapa
I believe the media converted should not affect this traffic.
Lukas
1,016 次查看
vsreekanth
Hello Lukas, we are planning to purchase this switch and converter for Audio and PTP traffic testing. Could you please confirm, whether it will support without any issues.
Thanks in advance. Good day!
1,005 次查看
lukaszadrapa
Lukas
1,061 次查看
lukaszadrapa
Hi Sreekanth,
100BASE-T1 can't be connected directly to a PC, you need media converter. Something like this:
https://www.nxp.com/products/interfaces/ethernet-/automotive-ethernet-phy-transceivers/ethernet-medi...
Or you can find a lot of others on the web.
Lukas
