PCF85063A: OS bit goes high when there is a dip in supply.
805件の閲覧回数
monishkora
We are using PCF85063A modularly. The problem we are facing is  - the OS bit becomes high even for the slightest dip in supply. Please suggest some solution to fix it.
4 返答(返信)
794件の閲覧回数
guoweisun
Please share with us your schematic firstly!
788件の閲覧回数
monishkora
PFA schematic.
771件の閲覧回数
monishkora
Our yearly consumption is 5000 pieces and we have already released the purchase order. So please look into this as soon as possible.
767件の閲覧回数
guoweisun
For your schematic:
1:Selectable integrated oscillator load
capacitors for CL = 7 pF or CL = 12.5 pF,you can use them instead your 10pF.
2: what do you mean slightest dip in supply? You use the battery do you monitor this voltage of battery? Can you catch the VBAT/INT/ CLKOUT when issue happened?
