I have a problem with one PCF2127 RTC IC.
The clock works, I can set and read the time via I2C.
The other feature I'm using is the backed-up RAM.
But when I write the registers and read them back, I get only zeros.
The PCF2127 responds, but the values are zero.
It looks like this:
Writing 5 bytes starting at address 0:
Reading the 5 bytes back:
On another unit (the same device type, identical MCU application) it behaves correctly:
I also tried writing 5 bytes @ address 64, but with the same result.
The schematics of the circuit:
It seems to me that the PCF2127 is defective.
Is there any procedure that could be used to test/identify the problem or restore the correct function?
Has this behavior been observed before?
Hi Tomáš,
thank you for your reply and sorry for the delay.
Michal
Hi Michal,
Thanks for your answers.
I am afraid that it will be necessary to perform a detailed analysis of faulty parts by our quality engineers in their lab. Our standard procedure for this is to submit a CQI (Customer Quality Incident) request through a distributor you bought the parts from (DigiKey).
Tomas
Hello Tomas,
please send me information to the procedure of submitting the CQI.
Is NXP involved from the beginning or does the distributor contact NXP?
I will have to have the part de-soldered.
Michal
Hi Michal,
It sounds like a quality issue. I do have a few questions to let us start:
1. How many parts have you tested so far and on how many of them have you observed this behavior?
2. Are all tested parts from the same batch?
3. What is the complete marking found on the top side of tested parts?
Tomas
Did this ever get resolved? I am experiencing the same issue with the exact same chips that we bought around the same time frame. Approximately 35% of our chips the RAM does not work at all, but every other feature works. Same exact boards, circuits, firmware etc...
Hello, we have 4 faulty tested pieces from 52 ICs from 2 batches,
which we bought at Farnell over 2 years ago.
The difference to the problem described here is, that we don't know, when the RAM get into this state (RTC works further very well).
And, when we discharge our connected GoldCap capacitor at VBAT (which unfortunately takes about 2 weeks in the closed device) we have full access to the memory again.
I adjusted the latter on the laboratory bench and unloaded the GoldCap. Then I can write to the RAM again and read back the exact content.
We have the following 2 batches:
Batch: 180817000009
48 pieces of PCF2127T
ACV098.
1 19th
knD18192
and
Batch: 180531000055
4pieces = PCF2127T
ACT659.
1 59
knD18072
Because, the order is more than 2 years old, we have received the answer from Farnell, that NXP will not make an CQC failure analysis.
Was the RAM of the PCF2127 not usable in all of these from the first start of device and permanently?
Does somebody has any idea?
Thanks for getting back so quickly. Can you remember the bath codes (week, year etc.)?
In out case these boards where produced last year and we didn't catch anything in production but have received complaints from costumers so it could be we have used components from the same batch.
This is what is written on one of the faulty IC's.
"PCF2127T
AFF 173
1 05
knD19202"
We had probably a 80+% fail rate on all the RTC's we got from this batch.
After we bought a new batch 100% have worked.
At the moment i do not have a problem with the Ram, but i have many problems with the acuracy of the frequency.
The data sheet says +-3 ppm. But our chips of the year 2019 have more than 19 ppm. If i understood our customer, they have several days per year time differences (> 100 ppm).
The batch code is:
ACU4771.1 05
knE18142
