I was upload tinyboot image on xspi
at that, my board shut down
after, SYSTEM READY LED is on, there is no response at putty
please help me
=> tftp a0000000 firmware_ls1028ardb_uboot_xspiboot.img
=> sf probe 0:0
=> sf erase 0 +$filesize && sf write 0xa0000000 0 $filesize <= shut out at this point
=> reset
Solved! Go to Solution.
Please prepare SD firmware image.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2012/firmware_ls1028ardb_uboot_sdboot.img
$ dd if=firmware_ls1028ardb_uboot_sdboot.img of=/dev/sdb seek=8 bs=512
note: /dev/sdb is device name of SD card.
After plugin in SD to the target board, please refer to the following switch setting to configure the target board as SD boot.
Under u-boot prompt, please program xspi image to the target board.
=> sf probe 0:0
=> sf erase 0 +$filesize && sf write 0xa0000000 0x0 $filesize
=> sf probe 0:0
Oh, I really thanks to you
It works very well!
