Hi folks.
I would like to how to deal otap.
1. step:
I would like to flahs KW38 board "otap client" + "otap boot loader" + "hello world" sample application.
I wish to confirm "hello world" on tera term.
How to flash 3 projects above into the KW38 board?
2. step:
I wish to revise "hello world" application to "hi there!" . It's is easy to revise the char string.
3. step:
And I would like to update "hello wordl" app by "hi there" app through IOT tool on the cell phone.
If you know any idea, please tell me.
Regards.
shigeto
I would like to update "hello world"
Solved! Go to Solution.
Hi Shigeto,
You can change the .s19 to .srec.
Go to the project Properties>C/C++ Build>Settings>Build steps>Post-build steps, and add this line:
arm-none-eabi-objcopy -v -O srec "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.srec"
Ricardo
Hi there! Richardo-san.
Thank you for your reply. I could go ahead !
But my iPhone's IOT tool doesn't read .s19 image file.
Do you know how to break through this problem?
Regards.
Shigeto
Hi Shigeto,
Ricardo
Hi there! Ricardo-san.
iPhone could open the .srec file and update through OTAP.
Thanks.
Shigeto
Hi shigeto,
Hope you are doing well. Could you please check this AN? KW38 - Integrating the OTAP Client Service into a Bluetooth LE Peripheral Device.
In section 5.4 you can see graphically a scenario of OTAP updates. The OTAP needs a BLE application with the OTAP feature integrated. So the hello world will not be a good example to test this feature.
But the Application Note would help you to test the OTAP feature.
Hope this helps.
Ricardo
