Image available for Grapeboard like Raspbian ?
782件の閲覧回数
wilbolinux
Hello everybody,
I'm experimenting on the grapeboard,
trying to build a working image.
Is there a way to download finished Linux images?
...and boot it from the SDCARD ?
That would be great !
Like Raspberrry with Rasbian :smileyhappy:
Thanks for your info!
Wilfried.
706件の閲覧回数
Pavel
The LS1012a supports booting only from QSPI NOR Flash. See the Section 24.1 of the LS1012a Reference Manual:
https://www.nxp.com/webapp/Download?colCode=LS1012ARM
See the Chapter 4.1.1 of the LSDK 18.12 documentation about LSDK using for the FRWY-LS1012A board:
https://www.nxp.com/docs/en/supporting-information/LSDK-KC-REV18.12.pdf
See also the Section 4.1.1.4 about deploying LSDK images on the board.
The Section 8.6.3 in the ARMv8_Targeting_Manual.pdf file contains information about program U-Boot in flash device using Flash Programmer.
This file is available in CW4NET folder.
Pavel Chubakov
