IRTC with Internal clock
rajashekargadda
hi all,
I am using following code when external crystal is removed, but after POR it's not working .
Very first time only it's coming , after POR it's not coming.
Please tell me how to handle this condition.
#include "drivers.h"
extern volatile uint8_t IRTC_Ram[32];
void main (void)
FLL_CtrlIRCLKEN(TRUE);
FLL_SelIRCSCLK(FASTCLK_SRC);
MCG_C1 |= MCG_C1_FRDIV(0x02);
SIM_SelRtcClk(SIM_RTCCLK_SRC2);
SIM_EnableModule(PORTH);
PORT_Init(PORTH,PORT_MODULE_ALT1_MODE, PIN6 );
GPIO_Init(GPIOH,GPIO_OUT_LOGIC0_MODE,PIN6);
arch_delay(250000);
GPIO_Set(GPIOH,PIN6);
SIM_Init(SIM_MODULE_CONFIG_OPTIMIZED_MODE_ONE);
PMC_Init(PMC_MODULE_LVDRE_OFF_LVDINT_OFF_LVWINT_OFF_CONFIG(PMC_LVDL,PMC_LVW1),PMC_INTREG_BGEN_OFF_BGBE_OFF_CONFIG, PRI_LVL0, (PMC_CALLBACK)NULL);
SMC_Init (SMC_MODULE_VLPS_ON_VLLS_ON_CONFIG);
SMC_SetMode(RUN);
IRTC_Init(IRTC_MODULE_COMP_OFF_CONFIG,
IRTC_TAMPER_PIN_POL_LOW_CONFIG(TAMPER_FILT_CLK_2HZ,4),
IRTC_TAMPER_PIN_DI_CONFIG,
IRTC_TAMPER_PIN_DI_CONFIG, 0);
MCG_C8 |= (MCG_C8_CME1_MASK );
MCG_C8 &= ~(MCG_C8_LOCRE1_MASK);
arch_delay(2500000);
GPIO_Clr(GPIOH,PIN6);
if((MCG_C8_LOCS1_MASK == (MCG_C8 & MCG_C8_LOCS1_MASK)))
FLL_Init (FLL_MODULE_FEI_20_25MHZ_CONFIG);
MCG_C8 |= MCG_C8_LOCS1_MASK;
arch_delay(25000);
else
SIM_SetClkMode (SYSCLK_MODE1);
SIM_SetClkDiv (SYSCLK_DIV1);
FLL_Init (FLL_MODULE_FEE_24MHZ_CONFIG);
arch_delay(25000);
while(1);
Help in this.,
