I have question about ASL5115YHZ
Earthmind
Hello
I use a ASL5115YHZ.
I'm checking Datasheet and I'm asking you a question because there seems to be no parameter.
I found the I/O High level input voltage(TxD, RxD), but there is no I/O output voltage.
I want to know the out voltage value(TxD).
Thank you.
TomasVaverka
Sorry, I am not able to answer the question with certainty. In general, for any unpublished parameter there is either no information or qualitative information on which we cannot commit.
However, as the ASL5115 uses VCC (4.5V to 5.5V range) for communicating, the VOH will be very close to this voltage. VOL will be close to 0V, I would say 0.4V max.
BRs, Tomas
