How to compile S32R45_ RSDK__ 1.1.0?
amei_liu
Referring to the file 'BuildAndRunSPTAppOnEVB_S32DS3.4. pdf', I compiled oal_driver.ko file reported an error while loading the module.
The Linux branch I am using is bsp33.0-5.10.109-rt, as shown in the following figure:
An error occurred during my execution of this step, as follows:
I ignored the error and continued compiling to generate oal_driver.ko。
Then I copied this file to EVB and encountered an error executing the insmod command. As shown in the following figure:
The version magic number (vermagic) of the kernel modules match the version of the Linux
kernel of the evb.
