We need know the significate ( referencec complete ) of this marking code
TJA 1042
K8 04
nD108
Thank you
Solved! Go to Solution.
Hello Edu,
The first line identifies the product type.
The second line contains an internal traceability code.
The third line contains assembly site information as well as the date code corresponding to work week 08 of 2021.
If you need an official document with additional information, please create a standard ticket.
Tomas
OK. Thank you , but can you confirm me the reference complete of the product ?
I would like if the reference is TJA1042T or TJA1042T/3.
Thank you
Hi Edu,
For the VIO (/3) version the first line is A1042/3.
For the non VIO version, the first line is TJA1042.
Tomas
OK
Thomas, thank you very much
It is now clear.
Edu
Hello Edu,
Tomas
