Typical purposes of current consumption computation are to scale power supply or thermal management.
1.
It doesn't matter if the device is sleeping most time or not. Anyway, power supply must be able to provide maximum current consumed by the device.
HV supply should scaled at max(IDD_LV_FULL + IDD_LV_PLL + IDD_HV_xx) current.
80 mA + 2.50 mA*fCPU[MHz] + 10ma + 3ma + 3.5ma + 4ma + 10ma = 410.5ma @ 3.3V, 150'C, 120MHz
Recommended supply current ~450ma.
2.
Thermal management. Use typical current consumption characteristics.
If LV internal ballast transistor is used:
P_tot = typ (IDD_LV_FULL + IDD_LV_PLL + IDD_HV_xx) * 3.3V
P_tot = (41 ma + 2.3 mA*fCPU[MHz] + 10ma + 3ma + 3.5ma + 4ma + 10ma)*3.3V = 1.15W @ 150'C, 120MHz
If LV external ballast transistor is used:
P_tot = typ (IDD_LV_FULL + IDD_LV_PLL)*1.32V + IDD_HV_xx * 3.3V
P_tot = (41 ma + 2.3 mA*fCPU[MHz])*1.32V + (10ma + 3ma + 3.5ma + 4ma + 10ma)*3.3 = 0.52W @ 150'C, 120MHz
3.
Power consumption estimation in HALT mode.
P_HALT = typ (IDD_LV_HALT + IDD_HV_xx) * 3.3V
P_HALT = (115ma + 30.5ma) * 3.3V = 0.48W @ 150'C, 120MHz
This estimation provides some margin since IDD_HV_xx consumption in sleep modes should be less than in full run mode.
4.
If you want to estimate average consumption in mixed sleep/run mode:
P_average = P_tot * duty + P_HALT*(1-duty)
Note. All estimations are made at Tj=150'C.
Paul
