Symlink? Also Eclipse
979 次查看
gibbon1
I tried downloading the code for USBM from here as a zip file.
https://github.com/podonoghue/usbdm-eclipse-makefiles-build
When I unzip it, using 7-zip is complains about duplicate file. Is this because there are symlinks in source tree?
Also is Eclipse required for building the USBDM code?
756 次查看
gibbon1
Okay, this is the problem under windows
UsbdmJniWrapper_dll
UsbdmJniWrapper_DLL
Hmm....
756 次查看
pgo
Senior Contributor V
Hi Matthew,
The directory name problem is caused by changing the name of the folder on Windows which is not case sensitive and then uploading to GIT which is.  The correct folder is UsbdmJniWrapper_DLL.
Eclipse is needed to build the Eclipse plugins.  There are make files for the C code.
bye
