Custom i.MX6 board bring-up problem
Search instead for
stephencox
NXP Pro Support
NXP Pro Support
Hi!
I'm trying to bring up a custom imx6q board using JTAG, because it has only NAND for booting and no SD connector attached. The design has imx6q and two DDR3 chips (MT41J256M16HA-125:E) populated. First of all I try to use the DDR stress test tool v2.40 to test and calibrate DDR3 memory. The test I took from here:
i.MX6/7 DDR Stress Test Tool V2.40
It starts, I can choose options but then it hangs. I don't know why and where in the code. I don't the sources.
        DDR Stress Test (2.4.0)
        Build: Dec 11 2015, 11:09:30
        Freescale Semiconductor, Inc.
        Chip ID
CHIP ID = i.MX6 Dual/Quad (0x63)
Internal Revision = TO1.5
        Boot Configuration
SRC_SBMR1(0x020d8004) = 0x00003050
SRC_SBMR2(0x020d801c) = 0x22000001
What ARM core speed would you like to run?
Type 1 for 800MHz, 2 for 1GHz, 3 for 1.2GHz
ARM Clock set to 1GHz
        DDR configuration
BOOT_CFG3[5-4]: 0x00, Single DDR channel.
DDR type is DDR3
Data width: 32, bank num: 8
Row size: 14, col size: 10
No chip select is enabled
Density per chip select: 512MB
Current Tempareture: 31
Please select the DDR density per chip select (in bytes) on the board
Type 0 for 2GB; 1 for 1GB; 2 for 512MB; 3 for 256MB; 4 for 128MB; 5 for 64MB; 6 for 32MB
For maximum supported density (4GB), we can only access up to 3.75GB.  Type 7 to select this
  DDR density selected (MB): 512
Would do you want run DDR Calibration? Type 'y' to run and 'n' to skip
Calibration will run at DDR frequency 528MHz. Type 'y' to continue.
If you want to run at other DDR frequency. Type 'n'
Enter the DDR frequency for calibration [350MHz to 528MHz]:
350
  The freq you entered was: 350
  Please enter the MR1 value on the initilization script
  This will be re-programmed into MR1 after write leveling calibration
  Enter as a 4-digit HEX value, example 0004, then hit enter
0004DDR Freq: 352 MHz
ddr_mr1=0x00000004
Start write leveling calibration...
running Write level HW calibration
Write leveling calibration completed, update the following registers in your initialization script
    MMDC_MPWLDECTRL0 ch0 (0x021b080c) = 0x00010001
    MMDC_MPWLDECTRL1 ch0 (0x021b0810) = 0x00010001
Write DQS delay result:
   Write DQS0 delay: 1/256 CK
   Write DQS1 delay: 1/256 CK
   Write DQS2 delay: 1/256 CK
   Write DQS3 delay: 1/256 CK
Please suggest what to do next
CommunityBot
Community Manager
This an automatic process.
We are marking this discussion as solved, due to a migration of a new community platform.
If you have additional questions, please create a new post and reference to this closed thread.
NXP Community!
CommunityBot
Community Manager
NXP Community!
