The SDK Generator Docs have been uploaded, here is the link SDK Generator Docs.
I have to say that the work is still on-going, 60% done. The outline is set and finished parts are all updated.
There are 4 md files:
SDK Generator Introduction and usage.md: Introduce the sdk generator and demo you how to install and use it.
Release Actions of SDK Generator.md: Illustrate the sdk generator release actions.
How to configure release_config file.md: Illustrate how to config release config yml.
Yml data record guide.md: Illustrate how to set ymls. Detailly, how to set ymls for boards/devices/components/applications/component_supports/NPIs/CMSIS pack/manifest, how to set ymls for projects, the configuration, the compilers, etc.
We are still updating it. After all parts are done, I will upload the docs files.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
