Features
Downloads
Revision History
3.0
Known problems and limitations
Workspace cannot contain space in the path.
By default, Secure Provisioning Tool does not burn all possible security features that are available. Only those required by the selected boot type are configured. The rest can be configured in OTP Configuration.
Windows
Workspace cannot be placed on different disk drive letter then the application is installed.
LPC Signed Boot Type:
LPC Key Store
The key-store is initialized only once in device life cycle and after that SBKEK cannot be changed. Details are described in documentation.
LPC/RTxxx Trust Zone
Configuration of Trust Zone is not supported for Unsigned image
i.MX RT1024
SD card boot device is currently not supported for MIMXRT1024-EVK board due to limitation in FlashLoader
i.MX RT10xx GPx fuse lock
lock for GPx fuse provided in previous versions was removed in V3 as the lock is not required for bootable image; However it is still recommended to lock the fuse; see `OTP Configuration` (on write tab)
i.MX RT11xx
If "lock after write" is selected in OTP Configuration, the write script will always burn all user requirements, because the "lock" status cannot be detected from processor
i.MX RT1015-EVK / Mac OS X
OpenSDA does not work On Mac OS X when the device has HAB enabled and UART port is used for communication. Either USB HID communication should be used, or the OpenSDA must be disconnected from RX and TX pins (jumpers J45 and J46) and device must be programmed via external USB to serial converter (3.3V)
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
