MCUXpresso Config Tools v7 Now Available
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Report Inappropriate Content
We are pleased to announce that MCUXpresso Config Tools v7 are now available.
MCUXpresso Configuration Tools is a product with set of tools that help users of all levels with a Cortex-M-based MCU solution.
Features
- Available as Web, Desktop application and MCUXpresso IDE plug-ins
- MCUXpresso SDK v2 support
- Multicore support
- GUI localized for English and Simplified Chinese
- On-Demand device data download for latest features and support
- Integrated directly within MCUXpresso IDE, standalone version supports other compilers and IDEs
Currently there are the following tools available:
Downloads
- It’s a part of MCUXpresso IDE
- In order to use it with other toolchains, download the installer for all platforms, please login to our download site via:
Please refer to MCUXpresso Config Tools documentation for installation and quick start guides.
For online version, login into MCUXpresso site:
Revision History
7.0.1
Mac OS X 10.15 operating system support added.
TEE tool: Displays correctly inaccessible regions in "Memory attribution map" view.7.0
7.0
- Added "Help | Kit/Board Information" option that displays information about currently used kit or board.
- Clickable Part number, Board and Kit name supported. It displays information about currently used processor, board and kit.
- Data Manager - supports clearing locally cached processors, boards, kit and components content.
- Configuration Preferences - supports custom copyright in generated sources
- TEE tool: Memory map is now interactive, cell double click opens its configuration.
- TEE tool: Memory map now displays peripherals space details.
- TEE tool: Added possibility to import memory configuration from MCUXpresso IDE project(s).
- TEE tool: Memory regions in Access overview are now grouped by memory type; all memory region aliases are displayed in a single row.
- TEE tool: Pins table now contains pin labels from the Pins tool.
- TEE tool: Additional validations and security setting recommendations.
- Peripherals tool: Tool can now generate binary output files.
- Peripherals tool: Component name is derived from the selected peripheral by default. It can be overwritten by a user.
- Peripherals tool: Documentation view improvements related to navigation added two new features - header with links in documentation content and selection box in header of view.
- Peripherals tool: Deprecated components have "(deprecated)" suffix in the add component dialog if there are still other instances of this type in configuration.
- Pins tool: Added automatic routing feature which can be used for conflict resolution in the current functional group.
- (MCUXpresso Config Tools only): Preferences - Added Dark theme support
- (MCUXpresso IDE only): Added SEMC/SDRAM stress tests, with RT support.
- (MCUXpresso IDE only): Added FlexSPI/NOR Validation tool, with RT support.
Community
MCUXpresso Config Tools Data
The Data for MCUXpresso Config Tools v7 was successfully deployed on the production system.
What’s new in data
The Data for MCUXpresso Config Tools v7 release provides following updates:
- 330 Kinetis, LPC and i.MX processors and 229 boards supported in total.
- Updated code generated by Pins, Clocks and Peripherals tool to support SDK v2.7 API.
- Peripherals tool support added for LPC8N04, KV11/4x/5x, KExx, KV3x and K22 (FN1M0 and FX512 memory variants only) processors. 200 processors supported by Peripherals tool in total - all processors in SDK v2.7 are supported by Peripherals tool now.
- Added 21 new Peripherals tool components for various Kinetis, LPC and i.MX RT processors. 103 components are available now in total.
- Improved DMA support in Peripherals tool - edma and lpc_dma components updated to support transactional and non-transactional modes, improved support of DMA request settings in other Peripherals tool components.
- Improved interrupt settings in Peripherals tool components, added default interrupt subroutine snippets.
- Added new Audio 1.0 and Device Firmware Update classes to USB Peripherals tool component, supported suspend/resume/remote wake-up feature, improved PHDC class support and USB endpoint settings.
- Added support of Memory validation for i.MX8MM processors, maintenance update of Memory validation/DDR tool supporting RT1020, RT1050, RT1060, RT1064 and i.MX8MM processors.
- Updated TEE tool for LPC55S6x processors.
- Various other small improvements and bug fixes of Pins, Clocks and Peripherals tool.
Supported processors, boards, kits and components
i.MX |
Kinetis |
LPC |
QN |
imx7ulp-14x14-arm2 imx7ulp-evk imx7ulp-evk-emmc imx7ulp-evk-emmc-qspi imx7ulp-evk-ft5416 imx7ulp-evk-lpuart imx7ulp-evk-mipi imx7ulp-evk-qspi imx7ulp-evk-sd1 imx7ulp-evk-sensors-to-i2c5 imx7ulp-evk-wm8960 IMXRT1050-EVKB MCIMX7ULP-EVK-REV-B MIMX8M-EVK-REV-B MIMX8MM-EVK-REV-C MIMX8MN-EVK-REV-A MIMX8QM-MEK-REV-B MIMX8QX-MEK-REV-B MIMXRT1010-EVK MIMXRT1015-EVK MIMXRT1020-EVK MIMXRT1060-EVK MIMXRT1064-EVK |
FRDM-K32L3A6 FRDM-K32L2B FRDM-K22F FRDM-K28F FRDM-K28FA FRDM-K64F FRDM-K66F FRDM-K82F FRDM-KE02Z40M FRDM-KE04Z FRDM-KE06Z FRDM-KE15Z FRDM-KE16Z FRDM-KL02Z FRDM-KL03Z FRDM-KL25Z FRDM-KL26Z FRDM-KL27Z FRDM-KL28Z FRDM-KL43Z FRDM-KL46Z FRDM-KL82Z FRDM-KV10Z TWR-KV58F220M TWR-KW24D512 USB-KW24D512 USB-KW41Z FRDM-KV11Z |
FRDM-KV31F FRDM-KW24 FRDM-KW36 FRDM-KW41Z HEXIWEAR HVP-KE18F HVP-KV11Z75M HVP-KV31F120M HVP-KV46F150M HVP-KV58F MAPS-KS22 TWR-K21D50M TWR-K21F120M TWR-K22F120M TWR-K24F120M TWR-K60D100M TWR-K64F120M TWR-K65F180M TWR-K80F150M TWR-KE18F TWR-KL28Z72M TWR-KL43Z48M TWR-KL82Z72M TWR-KM34Z75M TWR-KV10Z32 TWR-KV11Z75M TWR-KV31F120M TWR-KV46F150M |
LPC54018-IoT-Module LPC54S018-IoT-Module LPC8N04DevBoard LPCXpresso51U68 LPCXpresso54018 LPCXpresso54018M LPCXpresso54102 LPCXpresso54114 LPCXpresso54608 LPCXpresso54618 LPCXpresso54628 LPCXpresso54S018 LPCXpresso54S018M LPCXpresso802 LPCXpresso804 LPCXpresso812 LPCXpresso824 LPCXpresso845 LPC845BREAKOUT LPCXpresso55S28 LPCXpresso55S69 |
QN908XCDK |
Processors:
i.MX |
Kinetis |
LPC |
MCIMX7U3xxxxx MCIMX7U5xxxxx MIMX8MD6xxxHZ MIMX8MD6xxxJZ MIMX8MD7xxxHZ MIMX8MD7xxxJZ MIMX8MM1xxxKZ MIMX8MM1xxxLZ MIMX8MM2xxxKZ MIMX8MM2xxxLZ MIMX8MM3xxxKZ MIMX8MM3xxxLZ MIMX8MM4xxxKZ MIMX8MM4xxxLZ MIMX8MM5xxxKZ MIMX8MM5xxxLZ MIMX8MM6xxxKZ MIMX8MM6xxxLZ MIMX8MN1xxxIZ MIMX8MN1xxxJZ MIMX8MN2xxxIZ MIMX8MN2xxxJZ MIMX8MN3xxxIZ MIMX8MN3xxxJZ MIMX8MN4xxxIZ MIMX8MN4xxxJZ MIMX8MN5xxxIZ MIMX8MN5xxxJZ MIMX8MN6xxxIZ MIMX8MN6xxxJZ MIMX8MQ5xxxHZ MIMX8MQ5xxxJZ MIMX8MQ6xxxHZ MIMX8MQ6xxxJZ MIMX8MQ7xxxHZ MIMX8MQ7xxxJZ MIMX8QM6xxxFF MIMX8QX2xxxFZ MIMX8QX6xxxFZ MIMXRT1011xxxxx MIMXRT1015xxxxx MIMXRT1021xxxxx MIMXRT1051xxxxB MIMXRT1052xxxxB MIMXRT1061xxxxA MIMXRT1062xxxxA MIMXRT1064xxxxA
K32L3A60xxx K32L2B11xxxxA K32L2B21xxxxA K32L2B31xxxxA MK02FN128xxx10 MK02FN64xxx10 MK10DN512xxx10 MK10DX128xxx10 MK10DX256xxx10 MK11DN512Axxx5 MK11DN512xxx5 MK11DX128Axxx5 MK11DX128xxx5 MK11DX256Axxx5 MK11DX256xxx5 MK12DN512xxx5 MK12DX128xxx5 MK12DX256xxx5 MK20DN512xxx10 MK20DX128xxx10 MK20DX256xxx10 MK21DN512Axxx5 MK21DN512xxx5 MK21DX128Axxx5 MK21DX128xxx5 MK21DX256Axxx5 MK21DX256xxx5 MK21FN1M0Axxx12 MK21FN1M0xxx12 MK21FX512Axxx12 MK21FX512xxx12 MK22DN512xxx5 MK22DX128xxx5 MK22DX256xxx5 MK22FN128xxx10 MK22FN128xxx12 MK22FN1M0Axxx12 MK22FN1M0xxx12 MK22FN256xxx12 MK22FN512xxx12 MK22FX512Axxx12 MK22FX512xxx12 MK24FN1M0xxx12 MK24FN256xxx12 MK26FN2M0xxx18 MK27FN2M0Axxx15 MK27FN2M0xxx15 MK28FN2M0Axxx15 MK28FN2M0xxx15 MK30DN512xxx10 MK30DX128xxx10 MK30DX256xxx10 MK40DN512xxx10 MK40DX128xxx10 MK40DX256xxx10 MK50DN512xxx10 MK50DX256xxx10 MK51DN256xxx10 MK51DN512xxx10 MK51DX256xxx10 MK52DN512xxx10 MK53DN512xxx10 MK53DX256xxx10 MK60DN256xxx10 MK60DN512xxx10 MK60DX256xxx10 MK63FN1M0xxx12 MK64FN1M0xxx12 MK64FX512xxx12 MK65FN2M0xxx18 MK65FX1M0xxx18 |
MK66FN2M0xxx18 MK66FX1M0xxx18 MK80FN256xxx15 MK82FN256xxx15 MKE02Z16xxx4 MKE02Z32xxx4 MKE02Z64xxx4 MKE04Z128xxx4 MKE04Z64xxx4 MKE04Z8xxx4 MKE06Z128xxx4 MKE06Z64xxx4 MKE14F256xxx16 MKE14F512xxx16 MKE14Z128xxx7 MKE14Z256xxx7 MKE14Z32xxx4 MKE14Z64xxx4 MKE15Z128xxx7 MKE15Z256xxx7 MKE15Z32xxx4 MKE15Z64xxx4 MKE16F256xxx16 MKE16F512xxx16 MKE16Z32xxx4 MKE16Z64xxx4 MKE18F256xxx16 MKE18F512xxx16 MKL02Z16xxx4 MKL02Z32xxx4 MKL02Z8xxx4 MKL03Z16xxx4 MKL03Z32xxx4 MKL03Z8xxx4 MKL13Z32xxx4 MKL13Z64xxx4 MKL14Z32xxx4 MKL14Z64xxx4 MKL15Z128xxx4 MKL15Z32xxx4 MKL15Z64xxx4 MKL16Z128xxx4 MKL16Z256xxx4 MKL16Z32xxx4 MKL16Z64xxx4 MKL17Z128xxx4 MKL17Z256xxx4 MKL17Z32xxx4 MKL17Z64xxx4 MKL24Z32xxx4 MKL24Z64xxx4 MKL25Z128xxx4 MKL25Z32xxx4 MKL25Z64xxx4 MKL26Z128xxx4 MKL26Z256xxx4 MKL26Z32xxx4 MKL26Z64xxx4 MKL27Z128xxx4 MKL27Z256xxx4 MKL27Z32xxx4 MKL27Z64xxx4 MKL28Z512xxx7 MKL33Z128xxx4 MKL33Z256xxx4 MKL33Z32xxx4 MKL33Z64xxx4 MKL34Z64xxx4 MKL36Z128xxx4 MKL36Z256xxx4 |
MKL36Z64xxx4 MKL43Z128xxx4 MKL43Z256xxx4 MKL46Z128xxx4 MKL46Z256xxx4 MKL82Z128xxx7 MKM34Z256xxx7 MKS20FN128xxx12 MKS20FN256xxx12 MKS22FN128xxx12 MKS22FN256xxx12 MKV10Z128xxx7 MKV10Z16xxx7 MKV10Z32xxx7 MKV10Z64xxx7 MKV11Z128xxx7 MKV11Z64xxx7 MKV30F128xxx10 MKV30F64xxx10 MKV31F128xxx10 MKV31F256xxx12 MKV31F512xxx12 MKV42F128xxx16 MKV42F256xxx16 MKV42F64xxx16 MKV44F128xxx16 MKV44F256xxx16 MKV44F64xxx16 MKV46F128xxx16 MKV46F256xxx16 MKV56F1M0xxx24 MKV56F512xxx24 MKV58F1M0xxx24 MKV58F512xxx24 MKW21D256xxx5 MKW21D512xxx5 MKW21Z256xxx4 MKW21Z512xxx4 MKW22D512xxx5 MKW24D512xxx5 MKW31Z256xxx4 MKW31Z512xxx4 MKW35A512xxx4 MKW35Z512xxx4 MKW36A512xxx4 MKW36Z512xxx4 MKW41Z256xxx4 MKW41Z512xxx4 |
LPC51U68 LPC54005 LPC54016 LPC54018 LPC54101J256 LPC54101J512 LPC54102J256 LPC54102J512 LPC54113J128 LPC54113J256 LPC54114J256 LPC54605J256 LPC54605J512 LPC54606J256 LPC54606J512 LPC54607J256 LPC54607J512 LPC54608J512 LPC54616J256 LPC54616J512 LPC54618J512 LPC54628J512 LPC54S005 LPC54S016 LPC54S018 LPC54018M LPC54S018M LPC802 LPC804 LPC810 LPC811 LPC812 LPC822 LPC824 LPC832 LPC834 LPC844 LPC845 LPC8N04 LPC5526 LPC5528 LPC55S26 LPC55S28 LPC55S66 LPC55S69
QN QN908XC |
Components:
Components |
acmp adc12 adc16 adc_12b1msps_sar adc_etc aoi capt cmp_1 cmp cmt cop crc csi ctimer dac dcp dma dmic dspi edma eeprom elcdif enc ewm flexbus flexcan flexcomm_i2c |
flexcomm_i2s flexcomm_spi flexcomm_usart flexio_i2c_master flexio_i2s flexio_spi flexio_uart flexspi ftm gint gpio gpt hashcrypt i2c igpio kpp llwu lpadc lpc_acomp lpc_adc lpc_crc lpc_dac lpc_dma lpc_gpio_1 lpc_gpio lpc_i2c_1 lpc_i2c |
lpc_lcdc lpc_minispi lpc_miniusart lpc_rtc_1 lpc_rtc lpc_spi_ssp lpi2c lpit lpsci lpspi lptmr lpuart mcan mrt msg nfc ostimer pdb pint pit plu pwm qtmr rit rnga rtc rtwdog |
sai sctimer semc sha snvs_hp snvs_lp spdif spi system tempmon tpm trng tsens uart usb utick vref vspi vusart wdog01 wdog32 wdog wdt wkt wwdt |
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
