Generator Update on May, 24th
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Report Inappropriate Content
New features update:
- SDKGEN-967Support to automatically hide doc files in Xtensa workspace
Previously for Xtensa toolchain, developers need to use "hidden: true" in yml to hide documentation files in the workspace.
Now generator can filter files by type attribute to bypass doc type file for Xtensa, which means files with .txt .rtf .html .htm .readme .pdf .Doxyfile .xls .css extensions will not be added into the Xtensa workspace.
- SDKGEN-927Regard "hidden: true" in yml as "exclude: true" in <example>.xml as a workaround
The Manifest and Mcuxpresso IDE don't support source level "hidden: true" now. SDK generator uses "exclude: true" to represent "hidden: true" as a workaround.
In manifest 3.6, the source level "hidden: true" will be formally supported, see KEX-5920.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
