S32K1xx - NXP’s Model-Based Design Toolbox Installation
This video shows how:
- Install the Support Package Add-On
- Use of Installer Wizard
- Toolbox package download & install
- License generation and setup
9e0e3e377262f_Install.mp4
Video Player is loading.
Current Time 0:00
Duration 3:13
Loaded: 0.00%
0:00
Stream Type LIVE
Remaining Time -3:13
1x
- Chapters
- descriptions off, selected
- subtitles settings, opens subtitles settings dialog
- subtitles off, selected
- en (Main), selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
评论
06-02-2020
06:23 AM
Hello
Have a look here, please
https://i.youku.com/i/UNDY0MTM0ODcxMg==?spm=a2hbt.13141534.1_1.2
Hope this helps,
Marius
09-03-2020
12:20 AM
For more recent MATLAB versions, the license file shall be located in C:\Users\{UserName}\AppData\Roaming\MathWorks\MATLAB Add-Ons\Toolboxes
This is just an example from R2020a. So, just in case you are struggling to find the right location for your license file.
