I am designing a product using the PN7160 and creating an antenna. On the drop down list there is no option for the PN7160, is there another device I should select, or can I manually add the parameters?
Solved! Go to Solution.
Hi @gredpath :
The PN5180 can be chosen as NFC reader IC, which gives good starting value as such.
Please refer to AN13219: PN7160 antenna design and matching guide for more details.
Hi @gredpath :
