TagXPlorer Mirroring Fails with NTAG 413
jakefromoz
Hi guys,
I am having problems mirroring NTAG 413 with the latest version of TagXplorer v1.0.0.4. I believe there could be a bug in this version?
I am using a uTrust 3700F and when I try to mirror count, SUN and UUID, the values never update from m=000000000x000000x00000...
When I write the NTAG with an Android device, the mirroring works fine.
Thanks.
Tags (3)
Kan_Li
Hi Jake,
I just replied your private ticket,  please check it on your side.
Kan
jakefromoz
Hi Kan,
Thanks for the reply.
Still no luck with mirroring NTAG 413 with TagXPlorer. I have emailed you the screen shots of all my steps.
Is there something I am missing? Is there a bug in the software?
Thanks.
Kan_Li
This might be due that NDEF File CHANGE access rights are set to different value, and I managed to get it work on my side, and will pass my steps to you later.
Thanks for your patience!
Kan
zapata1
Hello
I have the same problem, could you tell me how to fix it.
Thanks in advance
