NTAG I2C Plus unable to read/write through I2c
2,064 次查看
niranjan_rao
hello,
I am working on NT3H2211 NTAG I2C.
I Could read/ write to the NFC chip through the host microcontroller and a NFC device.
Now all of sudden the I can neither read nor write into the NFC chip through I2C from the host MCU, but I can read/ write NDEF mesages through my mobile phone (NFC device). I can also read registers using the NXP Android app.
I check the I2C pin, everything is correct.
Can someone please tell me whats going on here?
Thank You
Rao
6 回复数
1,622 次查看
eljeffo
Are you able to detect other i2c devices when attached to the same bus?
1,622 次查看
niranjan_rao
Yes,  and I tried with a new ntag and I can read and write to it from the same bus
1,622 次查看
Kan_Li
Was the problem still there after change the ntag?
1,622 次查看
niranjan_rao
With new Ntag I can read and write through I2C,  with the old Ntag I cannot read and write through I2C
1,622 次查看
eljeffo
Try scanning all i2c addresses and confirm your chip is on the i2c address you expect. (check for NACKs)
1,622 次查看
niranjan_rao
Hello Jeff,
I scanned through all the I2C address, I get NAKs
