Cannot write to ISO15693 NFC tags using CLEV663 Development board
software_memo
I have a few Tag-It NFC cards (using ISO15693) from Texas instruments which were encoded by another manufacturer. I would like to use the same cards in parallel for my application too. To do this, I will require to write to some sectors of the NFC card memory.
My setup consists of a CLEV663 board which is controller by the NXP NFC Cockpit v5.9 and a few Tag-It cards.
I can perform all the read operations but I cannot write to NFC cards. Below is a list of the commands I executed and the response from the card;
Get System Information: Command: 0x2B, Flags: 0x12, Response: : SUCCESS, Data: 0F6B8AE52A000007E000003F038B
Get Multiple Block Security Status Blocks 0 and 1: Command: 0x2C0001, Flags: 0x12 Response: SUCCESS, Data: 0000
Read Block 1: Command: 0x2001, Flags: 0x12, Response: 00000000
Write Block 1 with data 0x33221100: Command: 0x210100112233, Flags: 0x52, Response: ERROR:RFProtocolType15693Service:Perform15693DataExchangeFailed: PAL_SLI15693,ISO15693
Even though the block security is not set, I cannot write to it. Can somebody please help?
fangfang
Actually Cockpit is designed for hardware test purpose, and usually used for the antenna design and optimization, and we provide NFC reader library for custom application, this library includes the example for  ISO15693 as the link.
URL:https://www.nxp.com/design/designs/nfc-reader-library-software-support-for-nfc-frontend-solutions:NF....
Have a nice day.
