Can NFC tags be inserted into plastic injected parts?
1,096件の閲覧回数
will2
I would like to know if an NFC tag could withstand the temperatures of being inserted into plastic injection parts such as PP at 130c
タグ(1)
2 返答(返信)
1,036件の閲覧回数
will2
I'm surprised that I am the first, maybe I'm breaking new ground and innovating?
1,036件の閲覧回数
Jonathan_Iglesias
Hope you are doing great, this is possible as you may know the NFC ICs can be found inside company badges, access control systems, etc.
so yes it is possible as long as you follow the guidelines in the ICs specifications, all of this documentation is under NDA.
other path would be you get in touch with our certified manufacturers so they RFID Ecosystem | NXP
Jonathan
