arm-none-eabi-gcc.exe: error: nosys.specs: No such file or directory in simulink build
snowpang
I encountered a similar problem with this [question](Solved: Simulink build error with example code - NXP Community) in the example of `extmode_s32k1xx` , Attempted all methods unsuccessfully, could you help me? The attachments are as follows
