The question about CanBus Configure in the Model Based Software Design
edenli
Hi Guys,
I used the the Simulink Block of MPC5643L from NXP,I wanna use it to realize the CANbus comunicatin,the External crystals is 8MHz,The target of the Baud Rate is 500K:
 I use the CANalyzer to display the signal,but the Error shown as below:
My configure about the CanBus Configure shown as below:
My calculation about the Baud rate as below:
Baud Rate=8000,000/(Prescaler*(1+(PROP_SEG+PSEG1+2)+(PSEG2+1)));
So i fill in the parameter,Prescaler=1,PROP_SEG=5,PSEG1=5,PSEG2=2,
Is there some thing wrong about the calcaulation?
The attachment is the Simulink Model.
Original Attachment has been moved to: can_simple_block1.slx.zip
dumitru-daniel_
Hi edenli
Something is wrong with the formula. It's not working on my side neither. Why do you want to change the XTAL frequency ?
constantinrazvan.chivu‌,
Can you please add the formula used to compute the CAN baud-rate depending on all parameters in the Toolbox.
Thank you!
edenli
Hi Daniel,
About the question ,Now i have solved it:smileyhappy:,but another question aomes again,i post it in a new topic ,haha,:smileygrin:,
If you have time to focus it
Best Regards!
Eden Li
dumitru-daniel_
How did you fix it ? Can you share the solution with us ? Where was the bottleneck ?
Thank you!
edenli
Hi Daneil,
The XTAL in MPC5643L dual motor board is 8MHz,so i need to change it.But the Error i can not solve.
