Hi everyone.
I am new using MBDT and FreeMaster. I recently adquired the S32K344EVB-172Q and I am trying to observe in FreeMaster a PWM signal that I have generated with the board itself. The signal is generated correctly because I have measured it in the configured PIN, but I do not know which block to use to store that signal in a Data Store Memory and display it in FreeMaster. I attach a photo of the model in simulink.
Thanks in advance.
