MCToolBox example project "adc_pdb_trigger_s32k14.mdl"
Search instead for
fengwang
Hi Radu,
     I use MCToolBox example project "adc_pdb_trigger_s32k14.mdl" , occur this error . Could you help me kill this error ?
 Thanks !
     Feng
raduivan
Hi Feng,
   Please delete and remake the link between ADC block and output port. From the screenshot you attached, the error occurs because those two blocks are not connected.
Radu
fengwang
Hi Radu,
     Thank you for me to solve error  again and again.
     I installed the "Motor Control Toolbox" again , i building the project in the simulink ,occur this error  :
i can't understand the "setting  up the target compilers" like this ; How can i  do it follow this .
 Many many thanks !
Feng
raduivan
Hi Feng,
   First you need to install the compiler you intend to use and after you need to set an Environment variable which will point to the installation folder. Let me know if you need more information.
Radu
