How to configure ADC using MIMXRT1170-EVK?
736件の閲覧回数
esantana
I am trying to set up the ADC without any interrupts but when I try to run it, it fails. I don't know if the configuration in MCUxpresso config tools is adecuated or if something is missing.
I attached the model which I am trying to compile.
Thanks in advance.
627件の閲覧回数
stefancinipeanu
Hello, @esantana
We have tested the ADC peripheral and we are not aware of any limitations. Did you try to run the ADC example on polling from MBDT IMXRT toolbox? What kind of error did you get when trying to build the application?
Usually, to use ADC in polling mode you just have to disable ADC interrupt from configuration file attached to the model, as depicted below:
Stefan.
3 返答(返信)
628件の閲覧回数
stefancinipeanu
Hello, @esantana
Stefan.
688件の閲覧回数
winter0147
Hello
I am just sharing here The MCUXpresso Config Tools are fully integrated into the MCUXpresso IDE, and also available as a standalone download for use with other supported IDEs, including Arm Keil, IAR EWARM and others. If using the MCUXpresso IDE, no additional download of Config Tools is required.
Hope so this information will help in resolving your  issue .
タグ(1)
721件の閲覧回数
Tyler691
The MIMXRT1170 SoC is configured to use the 24 MHz external oscillator on the board with the on-chip PLL to generate a 1 GHz core clock.
