How do I use Freemaster for MBD toolbox MPC5744P rev2.0.0
erichsu
Hello Sir,
How do I use Freemaster for MBD toolbox MPC5744P rev2.0.0?
If  disable the freemmaster settings, CAN Bus can send messages normally,
The setting screen is as follows:
The error screen is as follows:
Could you help?
Thanks a lot.
Eric
erichsu
Hi Daniel,
Freemaster CAN configuration is as follows:
My adapter is vector VN1630a in the list of supported devices, and show that communication could not be established after I clicked "Test connection" bottom .
The setting and error screen is as follows:
Looking forward for your reply.
Thanks a lot.
Eric
dumitru-daniel_
Hi Eric,
You have discovered a bug in the our setup.
I was able to reproduce the issue using this setup: MPC5744P evaluation board and IXXAT USB2CAN and the 500kb speed
I might have a quick and dirty fix for you until we will have a more stable hotfix. This fix works only with this setup which is similar with yours
Workaround:
- go to {toolbox install dir}\mbdtbx_MPC574xP\mbdtbx_pnt\mbdtbx_pnt\ folder and make a backup copy of mbdtargetmainlibpnt.tlc file
- copy and replace the file attached here in the {toolbox install dir}\mbdtbx_MPC574xP\mbdtbx_pnt\mbdtbx_pnt\ folder
- delete any previous generated model and build again the application.
Please confirm if it works or not in your case.
Thank you!
dumitru-daniel_
Hi Eric,
We need to know what we have done so far in terms of configuration.
From FreeMASTER/Project/Options you need to setup and configure the CAN communication.
Only some CAN drivers are supported. Is your adapter in the list of supported devices?
Thank you!
