HotFix: MBD Toolbox rev1.3.0 for MPC564xL
Search instead for
paulvlase
HotFix_1: Fix "Undefined function 'slsfnagctlr'..." when trying to generate code on R2016b/R2017a
NXP Tracking number: AST-527
Problem: If you try to generate code for any model on R2016b/R2017a, you will receive this error: "Undefined function 'slsfnagctlr' for input arguments of type 'char'."
Root Cause: Matlab API change.
Workaround:  Update the files attached in the following folders
{Toolbox install dir}\rappid564xl\rappid564xl\mscripts folder slsfnagctlr.p file
Customer Report: BUG report
Special thanks to Michael Verrecchia for reporting this issue.
paulvlase
HotFix_2: Fix license errors for DISK_SERIAL_NUM with less than 8 characters
NXP Tracking numberAST-619
Problem: If your HDD has a serial number with less than 8 characters, the license checking and validation will fail even if the license is correctly generated
Root Cause: Coding logic error
Workaround:  Update the rappid_hostid.p file attached in the following folder
Customer Report: Undefined function or variable 'lic_err'.
jjacp
Hi paulvlase‌,
Is this fix available for the MBD v2.0.0 Toolbox for the MPC5744P (Panther)? I'm running R2018a and am getting the slsfnagctlr error.
Thanks!
constantinrazva
Hello jjacp‌,
Yes, there is a fix available for Panther (MPC5744P). I have attached it here.
Please move slsfnagctlr.p file into
   {TOOLBOX_TOOL_ROOT}\mbdtbx_pnt\mbdtbx_pnt\mscripts
Kind regards,
Razvan.
jjacp
Thanks constantinrazvan.chivu! It works!
