Freemaster PCAN-USB Support
2,711件の閲覧回数
jjacp
I was wondering if the #freemaster development team has any plans to add support for the PEAK PCAN-USB device in their CAN plugin? Many of the supported CAN devices are either too expensive (Vector) or hard to find and purchase in North America.
Thanks!
タグ(2)
2,047件の閲覧回数
dumitru-daniel_
Hi jjacp‌,
Thank your for pointing this one to us. The FreeMASTER is going through an internal redesign process - therefore we are open to improvement suggestions.
I've captured this request as FMNG-21 (just for record - you will not be able to access the link) in our internal database.
7 返答(返信)
2,048件の閲覧回数
dumitru-daniel_
Hi jjacp‌,
2,047件の閲覧回数
alexisberthon
I'm wondering if redesign has been already done to support PEAK PCAN-USB ?
could I have an update on this ?
2,047件の閲覧回数
dumitru-daniel_
Hi alexisberthon‌,
Currently the FreeMASTER 2.0.8 (latest version) supports these versions of CAN drivers:
petrfajmon-b17364
Do you know is there are plans to support PEAK PCAN-USB in the FreeMASTER 2.0 ?
Thank you!
2,047件の閲覧回数
alexisberthon
Hello Petr,
thanks a lot for the update.
2,047件の閲覧回数
Bohrfutter
Hello Daniel,
We would also like to see the support of the pcan peak usb adapter! We have a PC bootloader application which only supports pcan and so we need to USB devices connected to the host one to flash (pcan) and one to debug (ixxat).
I just found the Kvaser CAN adapter is supported in the fresh 2.0.7.0 - even nobody asked for ;-).
My company could send you a peak usb can adapter if needed or we could help implementing the driver.
We have also implemented a MCU Freemaster CAN interface which has no access to the CAN hardware. In many applications we have already implemented a CAN handler and so we only want to pass the data[8], ID and length to the Freemaster code. If anyone is interested I can upload the modifications.
And talking about the Freemaster we found a small bug. When you have CAN enabled and an oscilloscope with 0=maxspeed (bus load ~30%) you have variable reading <1ms on the CAN bus but only data points every ~13ms in the Freemaster window.
Cheers
Sebastian
2,047件の閲覧回数
lucav
Hi Sebastian,
I'm interestedint your changes about the separation of CAN management from the Freemaster protocol
could you share it ?
Cheers
Luca
2,047件の閲覧回数
jjacp
Great! Thanks dumitru-daniel.popa‌!
