DCBV and Phase currents range measured_DEVKIT-MOTORGD?
Search instead for
liwuquan
NXP Expert,
Please help on my questions below since the documentation needed is not available on NXP website.
    • It is regarding DEVKIT-MOTORGD and DEVKIT-MPC5744 pair for motor control, the table attached here is about the current and DC bus voltage measurement on the pair, my questions are:
      1: please let me how much the number in the last column in the table suppose to be?
      2: how BEMF and PH current measurement is sharing the ADC channel? through jumpers? then which jumpers, how the configure should be?
      3: if you see there is anything not correct in the table regarding the pair of the board, please let me know.
      4:please provide schematics for your MOTORGD, if you do not have the updated version, the old version is fine to me.
      Thank you.
      Susan Li
dumitru-daniel_
Hi liwuquan‌,
I've bring to NXP attention the fact that the schematic is missing. The document is marked as Internal Use Only, therefore i can't share it until the team responsible with the document will not make is public.
All i can do is to help you with information since that is not restricted.
Therefore:
You can only choose between BackEMF or Phase current measurements one at a time. That is selectable via the J9/J10/J11 jumpers. There is a small legend on the board layout that tells you in which position the jumper should be.
Basically if you short 1-2 pins it will measure the phase currents (PMSM) while 2-3 position will measure the Back-EMF in BLDC mode
All the measurements range and resolution depends on J8 position.
J8 - short: the Vref  = 3.3V
J8 - open: the Vref = 5V
The DC voltage @5V Vref:
range= 0 to 45V
The DC current measurement @5V Vref:
-25 to +25Amps
The Phase Currents @5V Vref:
-31.25 to 31.25Amps
The Phase Voltage @5V Vref:
-Vdc to Vdc
Where did you got that information about J4 header? The correct routing is:
Unfortunately, i do not have the clearance to do that. Please contact your sales representative and ask him/her for this information. The document exists but currently is just for NXP internal use only.
